INTEK M-899
Bax
INTEK M-899
Post autor: Bax »
witam
czy ktoś miał już do czynienia z tym modelem?
73
[ Dodano: 2011-10-23, 18:25 ]
alazłem takie dane:
SPECIFICATIONS GENERAL:
Modes (AM, FM) As per selected band
Operating Temp. -10°/+55°C
DC Input Voltage 13.2Vdc ±15%
Size / Weight 153(L) x 50(H) x 185(D) mm / 750 gr.
RECEIVER
System CPUControlled Double
Conversion Super Heterodyne
IF 1° 10.695 MHz / 2° 455 KHz
Sensitivity 0.5μV for 20dB SINAD (FM)
0.5μV for 20dB SINAD (AM)
Audio Output Power @10% THD 2.5W at 8 Ohm
Image Rejection 65dB
Adjacent Ch. Rejec. 65dB
Current Drain 350mA (stand-by)
TRANSMITTER
System CPU Controlled PLL Synthesizer
Max Output Power 4W at 13.2Vdc
Modulation AM (85% to 90%)
FM (1.8 KHz ±0.2 KHz)
Output Impedanced 50 Ohm unbalanced
Current Drain 1300 mA (at no modulation)
FREQUENCY BAND / MODE PROGRAM (CE / R&TTE VERSION)
E1 ITALY/SPAIN 40CH AM/FM 4W
I2 ITALY 36CH AM / FM 4W
dE GERMANY 80CH FM 4W / 12CH AM 1W
d2 GERMANY 40CH FM 4W / 12CH AM 1W
EU EUROPE/FRANCE 40CH FM 4W / 40CH AM 1W
CE CEPT 40CH FM 4W (DEFAULT)
U ENGLAND 40CH + CEPT 40CH FM 4W
PL POLAND 40CH AM/FM 4W (-5 KHz)
Pd POLAND 40CH AM 1W / FM 4W (-5 KHz)
FREQUENCY BAND / MODE PROGRAM (INT'L VERSION)
RU WIDE BAND 25615-30105 KHz 450CH AM/FM 4W
PO WIDE BAND 25610-30100 KHz 450CH AM/FM 4W
C2 26830-27405 KHz 43CH FM 4W
S WIDE BAND 26515-27855 KHz 120CH AM/FM 4W
P2 WIDE BAND 26510-27850 KHz 120CH AM/FM 4W
INTEK M-899 VOX
Product code: 48899
€ 134,95 incl. VAT
To order this product, please input quantity and click on add to shopping cart.
Quantity:
[ Dodano: 2011-10-23, 18:39 ]
a tu unstrukcja po polsku:
http://maycom.pl/instrukcje/M-899%20VOX.pdf
[ Dodano: 2011-10-23, 18:57 ]
a tak wyglada
drovid
Post autor: drovid »
dolaczam sie do pytania i czy to lepsza alternatywa w porownaniu do Harego III ?
Dzieki. :hopla:
Mobil: President jackson 2 / Megawat 4000
Baza: President Lincoln / Sirio GejMajster
QTH : JO00DT
BeBek
Znak/ranga: SP9PP
Post autor: BeBek »
Odkopuje temat.
Czy miał ktoś doczynienia z tym radyjkiem?
Ciekawi mnie też ten słuchwko-mikrof + oddzielne PTT jak to w praktyce działa.
A najważniejesze jak z odpornością na zakłócenia.
Szukam czegoś do drugiego mobila i stąd te pytania.
SP9PP
kopernik
Post autor: kopernik »
161CBC002 kopernik op.mariusz
mobil:ranger 2950,zetagi 300,turbo 5000,cb-compact
baza:alan 560,k 375,ab 300,sirtel 5/8 gp 16, cb-compact
QTH N 53°04'83''47 E 23°03'58''64 134,7m+31,7m npm = czubek anteny
Wróć do „Intek”
